AMZER Dual USB PLATE eXtender Power Wall Charger (White)
Truly Plug n Play, now turn any standard outlet into a USB outlet in seconds. Simply plug the PLATE eXtender (tm) Power Wall Charger into a wall socket and you get convenient access to two USB ports and a single standard outlet. Charge your digital accessories all while still having access to power a power outlet! It features two charging ports: the powerful 2.1 Amp port, you need to charge your iPad or other tablets, while the 1 Amp port simultaneously charges your iPhone, iPod or other mobile devices. The compact size makes it easy to take it everywhere you go. NOTE: Charging cable not included. Features: Ultra compact and convenient wall outlet extender! Single grounded outlet is rated at 400 joules and defend against electrical spikes. Single USB port provides 2.1 amp for efficient and quick charge. Simultaneous charging by 2 USB ports - 1 amp each. Works with any USB cable. Instantly adjusts to voltage and frequencies. A must have accessory for your device if you are a frequent traveller. Specifications: Certified By CE, RoHS and UL. Input: AC100-240V. Output: 5V-1A 5V-2.1A. Surge Energy Absorption: 400 joules.
AMZER Dual USB PLATE eXtender Power Wall Charger (White) Review
I have this battery chargers for ages. I am still happy and I am using AMZER Dual USB PLATE eXtender Power Wall Charger (White) almost every day. This AMZER Dual USB PLATE eXtender Power Wall Charger (White) was reffered by my friend.
